Dufus
Aug 13, 2016Explorer
50A male plug wiring
I am replacing the male end of the plug. Does it matter which post red and black are on i.e. does it have to be the same on the male and female plug as long as ground and neutral are correct? thanks-
Bumpyroad wrote:Mandalay Parr wrote:
I made a mistake. I was thinking of the opposite adapter. 50 to 30.
I stand corrected.
Jerry Parr
years back I wanted to be able to choose the side of the 50 amp outlet had the best current and took my continuity tester to the RV dealers and tested their pigtails. IIRC all of them were wired the same so I ended up building my own adapter with a 50 amp plug and two 30 amp pigtails each to a side of the plug and could select the best one.
bumpy
