DufusExplorerAug 13, 201650A male plug wiringI am replacing the male end of the plug. Does it matter which post red and black are on i.e. does it have to be the same on the male and female plug as long as ground and neutral are correct? thanks-Show More
wolfe10ExplorerAug 14, 2016Yes, voltage is often different between L1 and L2. We are in a park right now where there is a 5-7 VAC difference. Basically, they have likely run more of the 30 amp sites on one leg than the other.So, we use the A/C powered by the "stronger" leg.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
Related ContentAdding power outlets in slide with no wiringReplacing 30amp male plug7 pin plug amperage rating?Fleetwood Angler wiring30A male & female replacement plugs
