- pianotunaNomad IIIHi CA Traveler,
Because the OEM relay had burned contacts within 12 months of my first use. Because the circuit also blew three sixty amp fuses. I replaced the fuse with a 50 amp automatic circuit breaker. It has been fine ever since.CA Traveler wrote:
pianotuna wrote:
Why so much higher than 50A?
I'd upgrade to one that is rated for at least 100 amps. Mine are 200 amps. - mena661ExplorerPiano and time2roll,
I'd prefer that PD53-100 but it's a bit over $300. I'll need to think about this. Thanks all. - I would go PD53-100 with contactors. Randy has them.
Unless you also want voltage protection then look at intellitec. - CA_TravelerExplorer III
I'd upgrade to one that is rated for at least 100 amps. Mine are 200 amps. - pianotunaNomad IIIHi mena661,
I'd upgrade to one that is rated for at least 100 amps. Mine are 200 amps. - mena661ExplorerI'll take a look at the ESCO, thanks for the replies.
- CA_TravelerExplorer IIIThe ESCO LPT50BRD ATS is widely discussed on a Monaco forum.
- garyemunsonExplorer IIYou might want to see if you can get a replacement coil...that's usually what fails.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
