wa8yxm
Jan 16, 2019Explorer III
Cummins12V98 wrote:
"NOTHING in yoru RV needs 240 volts (Minor exception if you have an ALL ELECTRIC RV that may not be the case) Everythign is 120 volt"
HMMMMM, I have a 220V Washer AND Dryer. I also have 220V Cheap Heat.
Bottom line I would consult a QUALIFIED Electrician.
You will note I too suggested a qualified electrician or at least a licensed one. I won't bore anyone with the list of reasons why.
Your 220 Volt W/D is not designed for RC that's a Residential device I'm sure. But it won't mind 208.. Neither will the cheap heat. Just a few less BTUs.
THe element in my water heater says 240 volt (1500 watt) but it works just fine on 120. only 375 Watts though.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
