Handbasket
Jul 10, 2014Explorer
My then-new small Onan Microlite 2800 in the Tiger developed the dreaded 'starts, stops when the start button is released' symptom after only about 8 hours of use in late spring of '06. A supposedly good RV shop kept it for 3 weeks, then returned it with no fix. The Cummins-Onan distribution & service center in Spartanburg SC kept it for 2 weeks, but fixed it.
Yes, they had to replace the rotor & stator both. As I understand it, they only come in matched sets. I was glad it was under warranty when I saw the bill. It cost Onan just short of $1700! It had to go dack one more time after a few hours of use when I found that they hadn't tightened a screw on the governor arm fully; no charge. Then last year when I had it out I found that one of the isolation mounts hadn't been replaced when they reassembled it. I called, and they shipped it overnight with no argument or charge. Just guessing, they maybe knew the tech who had first worked on it wasn't the best.
Jim, "Mo coffee!"
Jim, "Mo coffee!"
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
