RV-1_2n-FUN's avatar
RV-1_2n-FUN
5500 Onan starts then dies, help please
2008 Onan 5500 that I neglected and did not run every month with load since May. Using start switch on the generator, first priming then start the gen. It starts and runs ONLY as long as I hold almost completely closed the butterfly under air filter. If I take pressure off the B-fly opens wide and sounds like gulping air then shuts down with code flashing 36. Reset code, prime and start up and again runs only by holding closed the butterfly. Sprayed plenty of Seafoam in to no avail.
Any ideas of problem???
TIA
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
