LittleBill
Apr 24, 2015Explorer
wa8yxm wrote:
5 amp is a lot to push through a LED less you are designing flash bulbs..And with multi-led Panels you would need matched led's and when one burns out the rest become flash bulbs.
But I see it is also a VOLTAGE regulator.. add a simple resistor and your LED's are very happy (one per led or with 5 volts one for every two led's).
its a constant current regulator, no need for him to use resistors, he can adjust current via a POT.
i like that both current and voltage are regulated. might pick one up for a project i got going with lipo
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
