Tyler0215 wrote:
Have the outside repaired, replace fridge with a dorm unit or household fridge, whichever fits.
Awning fabric is readily available. Not an impossible job to replace with help.
Remove old flooring before you put down the new.
Replacement decals are probably available, or just remove the old ones and go without.
A dorm size is to small for our needs and anything larger will not fit as the furnace sits under the frig.
Sounds good on the awning. All it should cost is the replacement fabric and some cold beer and a BBQ cookout!
Was planning on removing old vinyl and carpet. Should I use the underlayment or not?
I've seen the decals on eBay and really not the happy with the selection. If there are other sources I would like to know.
