wolfe10
Oct 26, 2014Explorer
Big Katuna wrote:
My 05 single window never changes from 6 when I switch on brakes.
Can it be reprogrammed?
That is very unusual. Most chassis makers spec their Allison ECM's with a "lower than 6th gear" pre-select for the exhaust brake-- 2nd and 4th being common choices. But, yes any gear can be programmed in.
My first question is whether your coach is properly wired and working as designed. Second would be whether the Allison ECM is properly programmed.
Said another way, if is like 99% of coaches that have an OE exhaust brake, the signal goes from brake switch/throttle switch to the Allison ECM and then to the exhaust brake solenoid. Before spending money on the Allison ECM reprogramming, make sure everything else is working as it should. If, for example the relay does not receive a "throttle is closed" signal, the exhaust brake will not come on and the Allison shift pad WILL stay "6".
Your chassis maker is the best source of information on this.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
