Ed_Gee
May 15, 2021Explorer II
In most RVs you cannot safely just replace your batteries with Lithium batteries. You need to determine if your RV charger will properly work with Lithium batteries. You also are likely needing to modify the way the engine alternator charges the house batteries if they are changed to Lithium. These are considerations the OP needs to make.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
