BFL13
May 15, 2021Explorer II
jaycocreek wrote:
In an actual capacity test with a heat gun,Will only got 1156 watt hours or 93+ amp hours out of the Battleborn 100ah battery..I only posted because someone here keeps saying Battleborn is 120ah but test clearly show it is not...
Did not see that one, but I doubt a heat gun would be at the 20 hour rate of 5 amps for a 100AH battery to get the AH rating.
WP seems to be pretty good with numbers and is fast talking, so hard to know if he is a flim-flam man or what he is actually doing. I don't "get" WP as a sort of LFP guru/expert for that reason. IMO check his numbers very carefully and still wonder what he might have got past you.
OTOH, you might still win the Kewpie doll! :)
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
