BFL13
May 15, 2021Explorer II
jaycocreek wrote:
Will Prowse explains somethings very good and others not so much...For someone completely new to lifepo4 he is about the only one trying to explain things...
Battleborn capacity test with heat gun
Ok watched that. It was not an actual capacity test wrt the ratings of 100 AH but was a comparative test using Wh. The draw was at 80 amps if I got that right. I missed what that 1200Wh at the start was all about.
It was sort of a blur, but AFAIK he also reduced the amp load before the end for some reason I missed. ?
Anyway, whatever he was doing there was not an AH capacity test using the 20 hr rate.
"The hand is quicker than the eye" :(
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
