StirCrazy
May 16, 2021Moderator
jaycocreek wrote:
In an actual capacity test with a heat gun,Will only got 1156 watt hours or 93+ amp hours out of the Battleborn 100ah battery..I only posted because someone here keeps saying Battleborn is 120ah but test clearly show it is not...
ya it is deciving also, when he did his tear down of a battleborn he said the cells added up to more than 100 ah, in his capacity test the bms shut off the battery at 107 ah ( believe if my old memory is remembering the right video) and he figures that was the limit they had it set for. it gets confusing when you have a BMS that ou can set for shut off points and charg limits because a draw down test wont tell you the actual AH of the physical battery but only what the settings will let you use.
Steve
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
