rockwind1's avatar
rockwind1
Explorer II
May 11, 2014
6 volt battery issue question about load
so I have 2 different pairs of 6 volt batteries on my toyhauler. one set from Costco, the golf cart bats, with a date on them of 4/12. they had been sitting in my garage for about a year-year and a half on a battery tender jr. , with it showing green
the other pair came with the toyhauler, they are 2 6 volt agm batts, owner said they were still good and they seem like it but,,,,
when I charge both pairs of batts to full charge, 13.5 or 13.6, as soon as I put a real load on them (like pulling 7 amps thru the xantrax 1800 inverter), the digital volt meter from the xantrax readout shows down to 11.1 volts, if I put a small load on them, like the heater fan, the volts fall from 13.5 to 12.5 or 12.4.
from what I understand, going down to 12.3 volts, you have essentially used 40-50% of the battery capacity?
my question is, are these batteries toast? obviously, each one of the pair of 6 volt batts should have at least 200 amp hours, so total 400 amp hours? and the volts drop pretty quickly, I would have assumed if I pulled 7 amps on the inverter, I should get at least 25 hours hours before I hit 12.5 volts (50% discharged). (200 amp hours divided by 8 amp load = 25 hours
any response is appreciated ( I am unsure of the date of manufacture of the agm's)
Moved to Tech Issues forum from DIY.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
