Tiggs
Oct 08, 2013Explorer
Yes, I did verify that the proper light came on. I had all the lights working prior to my chewing up the cable. I had all but the clearance lights working when rewired everything through the connector box and had it hooked up to my own tow vehicle -- except the original problem on the clearance lights. I had all the lights working, even the clearance lights w/license plate light using the 12V power supply.
From the trailer side, the lights were working on the following wire colors. I used the same colors at the connector box to the 7 pin plug. I've also listed the pin # where the wire appears. I've verified that the pin # goes to the correct wire color at the connector box and that I have continuity through the new cable length.
Brown is right turn signal to pin # 2
Blue is electric brake to pin # 3
Red is left turn signal to pin # 5
green is running lights to pin # 6
yellow is aux. power to pin # 7
black is 12V to pin # 1
white is ground to pin # 4
If there is a circuit breaker for the 7 pin connections in the distribution center, it isn't labeled as such. I've even pulled the fuse from the 12V deep cycle house batteries to see if I blew it.
Carolyn
Carolyn
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
