wnjj
Oct 13, 2013Explorer II
Tiggs wrote:
I hitched up the TT to the TV and connected the 7pin plug. All my lights work, even the clearance lights and the license plate lamp. I can't believe that it was looking for the additional ground from the vehicle but it appears that is so?
Carolyn
You need to add a wire to your splice on the ground wire to a loop terminal which you clamp under a bolt.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
