toedtoes
May 26, 2021Explorer III
When you try to start it do you see fuel shooting into the carb? If not, then you have a fuel issue (clogged filter, not enough fuel, etc).
Did you check to make sure you're getting a spark? If not, check the coil and ignition module.
Did you check the battery?
Been there with my clipper. Have had all the above as the cause.
