KD4UPL
Mar 16, 2020Explorer II
From your description I would say yes; you would connect the hot 12 volt + wire from the truck to the one from the camper. You should also have an equally heavy gauge wire for the negative connection. This is usually white from the truck, hard to say on the camper.
The blue electric brake wire from the truck will not connect to the camper since it doesn't have brakes.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
