rayroof10ExplorerOct 24, 201395 fleetwoodhaving problems getting my furnace to come on in my camper, the blower will run but the furnace won,t light. both tanks or full any suggestions it is a 95 fleetwood. Thanks
wolfe10ExplorerOct 24, 2013Low voltage is the #1 cause of this-- fan speed not enough to close the sail switch.What is voltage at the furnace?Obstructed air return and/or closed vents and/or crushed ducts can also restrict air flow enough to cause the sail switch to stay open.Gas valve and ignitor ONLY work once the PC board sees the closed sail switch.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
Related ContentFleetwood Angler wiring95 Fleetwood BounderRt. 95 north95 fleetwood furnaceDoes 95 Fleetwood Jamboree Rallye have Electric Fnt Brakes?
