Gjac
Sep 12, 2014Explorer III
If the flame stays on continually which is how I understand your OP then there are several things I would look at. 1, How long have you waited for the temp to drop in the reefer section? Mine needs 12 to 24 hrs in warm to hot weather. 2, Check to see if there is any rust that has fallen down from the flue blocking the burner tube slots. Also fine rust particles can build up inside the tube itself blocking the flow which needs to be cleaned out. 3, While you have the tube out clean the orifice it may be dirty. 4, Check to see if propane has enough pressure for a good flame. 5, Check to see if the slots on the tube itself are rusted out which would cause a smaller flame.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
