theoldwizard1
May 25, 2021Explorer II
phillyg wrote:
Crawl under and tap the starter solenoid with a hammer; it may have frozen up from little use.
Good suggestion, but check the connections at the starter solenoid near the battery and the battery terminals. If they are the least bit suspect, disassemble and clean them.
While you are underneath with your hammer, check the connections on the big cable to the starter. Again, if the least bit suspect, disassemble and clean.
Once all connections are clean, then do the "tap" test.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
