steveh27's avatar
steveh27
A Bad Day mechanically
The Check Engine light came on in my 1997 Xplorer 230XL camper van. I got poor mpg. A local service guy read the code as oxygen sensor exhaust system. But they were too backed up, so I took it to my muffler shop that I've used for 30 years. They installed 2 new sensors, checked the rest of the exhaust system, the brakes and did a lube job. I paid for it and went to the RV and it would not start. No turning over, no clicks, nothing. The battery is good. The starter is 4 years old. It had been fine. They will check it today.
While waiting for a cab I went inside and found the fan-tastic roof vent fan seriously damaged. The inside frame pushed down and broken, the cover had several big cracks. It did open and run, but needs replaced. The manager said he would fix it so he knew they raised it too high on a lift and hit the ceiling. I had told them to watch out for that.
He had already ordered one on AMazon when I gave him the manual and installation instructions on this one. I told him I was worried about him doing this job as it required special caulk, etc. He will call Fan-tastic today. I am rv-less and was planning to leave tomorrow for a 800 mile round trip to PA for spring turkey hunting with my brother. I don't see that happening now.
I am more worried about the fan replacement than the RV not starting. I figure that is a simple connection, fuse or some other easy to fix problem once found.
  • That's really unfortunate. I'd put a Maxx Air over the broken fan, fix the starting issue , and go hunting.
    Worry about the fan when you get back. Gobble gobble gobble.
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 16, 2025
