pianotuna
Jun 21, 2015Nomad III
Hi Bill,
Kyocera is one brand name that comes to mind. I'm certain there are others.
Another path would be to use a panel with an integrated charge controller such as ac_solar_panels This would essentially eliminate voltage drop as you would be transmitting 120 volts a.c.
Trackrig wrote:
Don, this is the OP.
I've started doing a little more looking at panels. If you want to make a suggestion on one large higher voltage, I'd certainly look at it.
Bill
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
