Bud99 wrote:
Are A G M Batteries worth the extra money? Do they outlast wetcell Batteries or am I just as well off buying 2 wet cell batteries for use in my 5th wheel?
Thanks,
Bud99
Do hornets nest.. The following is my opinion this is based upon both research AND Experience.
Are they worth the extra money  NO (With one qualifier below)
Do they outlast PROPERLY CARED FOR wet cells.. Again NO
Are you just as well off buying wet cells.. Most likely.
Now, the qualifiers
In some cases it is very hard to get to the batteries for maintenance,, AGMs are a maintenance free design and there is one feature all wet-cell designs (Both flooded and Maintenenace free) have the AGM's Lack... A "This side up" sticker.
This means you can mount them any way you need to mount them On end, On side, even upside down though that is NOT recommended.
In my expierence,, I put a pair of Group 31 MK AGM's on their own circuit, Just them and a couple thousand watt Inverter/converter.
These were the last batteries to be installed in my motor home.. The other batteries consisted of the Flooded Wet Cells (GC-2 format) Interstate U-2200's installed at the factory and some older Maintenance free Marine/Deep cycle (Purchased BEFORE the Motor home)
The AGM's were last in.
They were also first out due to failure in 2011
I did not replace the Interstate U-2200's till this year.
I was not pleased.
In doing research:  Many brag about how long the AGM's last compared to other batteries.. Strangely  LIFELINE the #1 AGM maker, is not one of those so bragging.
