Harvard
Oct 17, 2014Explorer
Dutch_12078 wrote:Harvard wrote:Dutch_12078 wrote:
The safety ground lug should never carry any significant current unless there's a fault elsewhere. A "hot skin" condition only occurs if the neutral and ground are bonded in the RV in violation of the NEC or shorted together, AND the power source hot and neutral are reversed. Just the absence of the ground alone should not cause any problems, although it's certainly not advised to leave it that way in case a fault should occur.
Not so, there is stray capacitance between the H, N and G conductors through out the RV. When the G is allowed to float it will attempt to find a stable level 1/2 way between H and N or some where < 55 VAC. But the extent of current behind this voltage is in the order of being < 5 milliAmps otherwise it would trip GFCIs if there was a GFCI supplying the RV.
Also, quite separate from the presence of 120VAC H and a N circuit wiring, if you park an RV under HIGH VOLTAGE distribution wires (ie 6,000 VAC) and the RV IS NOT CONNECTED to Shore Power AND the RV has no conductive connection to EARTH, that RV frame will develop a hot skin. This type of hot skin is due to the RV being an isolated capacitator plate between the high voltage wire and EARTH.
IMHO.
What part of "significant current" didn't you understand?
Sorry, I should have been more explicit.
A "hot skin" condition is generally accepted as being an RV which has a measureable voltage between the conductive surface (or chassis) of the RV to Earth. It is usually detected by a person in contact with Earth and happens to touch the RV conductive surface.
This "hot skin" condition can be the result of a one fault condition, on a 30 Amp RV. The one fault being an open ground where the RV conductive surface is allowed to float. If there are no other paths from RV chassis to Earth this voltage will amount to be as much as 1/2 the applied H to N VAC on a 30 Amp RV. (I have no personal experience with a 50 Amp RV having an Open Ground Conductor to know what the expected chassis to Earth VAC might be)
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
