time2roll
Jan 27, 2018Nomad
rsqfyrmedic wrote:Thermostat needs solid 12vdc on both the fridge and air.
I tested all the breakers and fuses...working fine on the genset but dead on shore power. There is power at the transfer switch so I don't think it's the twist lock plug. I'm thinking it might be the converter itself is dead but why would everything work on the generator?
Do the lights and water pump work?
Do you have a battery switch in the off or storage position?
What is the battery voltage?
Probably need a new transfer switch too.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
Related Content
- Feb 01, 2026Community Alumni
