Sam_Spade
Jan 28, 2018Explorer
rsqfyrmedic wrote:
Breakers (in the house as well as the MH) good and I'm plugged directly into the 50 amp I've been using...no adapters, GFCI's are all good.
Sounds to me like there is some assuming going on there.....and that usually is a BIG mistake.
You need a meter to check the voltage one step at a time, starting at the 50 amp outlet that you are plugging into. Things fail, including wire connections and circuit breakers.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
Related Content
- Feb 01, 2026Community Alumni
