dougrainer
Sep 17, 2014Nomad
HOW do you know the roof AC is causing this problem??? I have NEVER seen such a problem as you state and the fact that ALL 120 breakers are off while the power is restored and the Converter relay kicks back in points to your SHORE supply and/or Power Cord having a problem. There is NOTHING in the roof AC that will cause any type of power interruption, unless your supply voltage power is not above 110 volts. If the roof AC had a problem, it would trip the dedicated 20 amp breaker in your RV breaker panel for the AC. The Converter has nothing to do with the AC operation, it only supplies 12 volt power to the RV. Doug
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 20, 2026
