otrfun
Sep 17, 2014Explorer II
If the voltage to your TT is good (as per RoyB's suggestion), I'd pursue the possibility of a loose power connection feeding your a/c. Having a 15-20 amp load go full-on/off/on quickly (from an intermittent connection) would explain some of your symptoms. I'd remove power, then check the wire nuts & connectors located in the immediate area of your rooftop a/c unit (both inside and topside, underneath the shroud), plus the a/c breaker terminals, for secure connections.
Good luck!
Good luck!
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 20, 2026
