dclark1946's avatar
dclark1946
A/C Condenser Evaporative Cooling Assist
I am wondering if any company offers an evaporative cooler designed to reduce RV A/C condenser inlet air temp to assist in 95+ deg temps? I designed such a system (inspired by some mechanical engineers I worked with) for our residential central A/C back in the late 70's when the condensing units had coils only on one side making the design much simpler. I had the system in place during the torrid 1980 TX heat wave when peak temps reached 113 deg. The system functioned as a nearly constant condenser inlet temperature regulator. As the temperature increased during the day the relative humidity decreased and the evaporative cooling delta t increased so for outside ambient air temp of 113 deg the condenser inlet air temp was 85. This reduced compressor hgh side pressure and consequently lowered current draw. Our unit cycled nicely even in those extreme temps.
The main complication for RV A/C applications to me is the condensing air inlet being on both sides of the unit requiring some ducting of the evaporative cooler's output air or maybe an enclosure over the whole unit except for the back for the condenser's air exhaust with a single duct feeding the cooled air to the enclosure. Maybe just block off the side inlets and feed the cooled air into the units cover.
Based on Coleman's Evaluating RV A/C performance document, you would expect compressor current draw to increase 1A over LRA for every 5 deg above 95 and also decrease the same amount for every 5 deg below 95 so there would be benefits for reducing power consumption.
I would welcome any thoughts/feedback.
  • pianotuna wrote:
    dclark1946 wrote:
    I don't understand how any kind of evaporative cooler can function to lower temperature in a closed environment regardless of where it is located. The cooling process adds moisture to the air raising the interior humidity and if it is just recirculating it keeps adding more humidity to the air reducing the cooling. To me it seems somewhat similar to operating a window A/C unit totally inside your closed RV with the cooled evaporator air and heated condenser air both being blown into your RV.
    Then you don't understand that when water evaporates the temperature is lowered.
    It is NOT at all similar to a window A/C operating inside.
    I must be doing a terrible job of communicating on this post. I was trying to use an analogy with the window unit substituting temperature for humidity. I fully understand that when water evaporates the air is cooled. The lower the relative humidity the greater the cooling. I used that principle in the A/C assist evaporative cooler I designed, built and used successfully for years. However when the air is cooled by evaporation the air moisture content is increased. If you keep recycling the air through the evaporative cooler in a closed environment (no outside air brought in) the relative humidity will continue to increase and the evaporation process will give you less and less cooling. I hope I have explained it clearly.
  • In the 70s and 80s I added sub coolers... water cooled exchangers and Penn head pressure control valves in the liquid lines of condensing units that were in hot equipment rooms and overworked ACs and that worked terrific to increase NRE - net refrigeration effect.
    I remember seeing swamp cooler frames and pads that could be added to the face of condenser coil's and it dripped water over the pads just like a swamp cooler and cooled the air before it went thru the cond. coil. I thought that was a great idea but I was working at a plant with well over 100 RTUs and I had a bunch of large ones, up to 80 tons, with horizontal coils and swamper pads wouldn't have works. We had excellent water with very low hardness and I ran lawn sprinklers under those coils until I could add liquid line subcoolers, cooled with plant chilled water, to them.
    I've been thinking about adding something to my home condensing unit. Swamper pads require staying on top of the maintenance. If the water were to stop, there would be a big air restriction in front of the coil, but the liquid line subcooler with a Penn control valve is fully automatic and will maintain a preset liquid line temperature no matter what the conditions are. Also, there's no negative effect if the water stops.
    I also added a water subcooler to my recovery machine and it cut recovery time to a fraction of the time. Craig
  • Craig,
    Thanks for you comments on the commercial application of evaporative cooling to assist A/C operation. I found it informative.
  • We have a 34' Cherokee with a 15k BTU Dometic AC unit. We've had it in high humidity 98 degree weather in Alabama and it keeps up just fine. There may be some issue with the AC unit or, if it's ducted, it might have a leak that's blowing cold air into the attic area.
  • PatJ's avatar
    PatJ
    Explorer II
    I like the idea and would love anything that would make RV AC more effective or efficient, and wish you the best of luck overcoming the issues with using water to assist the condenser in an RV.
    In the meantime, it seems to me the effort is best spent just using a much larger condenser and much larger condenser fan for increased efficiency. Of course then we would need a variable speed condenser fan and compressor to keep the pressures in check, maybe an electronic TXV, and a computer to run the whole thing. This is starting to sound like a modern mini-split!.
    Most current RV roof air conditioners use 1960s/1970s window banger technology. They could make a rooftop RV air conditioner with a very superior performance and efficiency to what's available now, but it would be $4500 instead of $800. You and I may buy one for that, but unfortunately we are the minority RV buyer at the moment.
    I think 90% have this issue. Some worse than others.
    We do have the Coleman Mach 3 PS 13.5 which has a higher efficiency compressor (scroll I think) and larger condenser compared to their standard 13.5 Mach 3. Currently only have 15A service in our back yard where our trailer is parked and that works well except in the middle 9f Aug. in full sunlight.
  • Our rv ACs and existing compressors would benefit GREATLY with larger coils and more airflow to bring the DTs down and that would automatically increase efficiency... N.R.E. The evap. would bring the sensible load down better and not so much the latent load. But, we only get cheapo engineering/design in our rv junk. Craig
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
