dclark1946's avatar
dclark1946
A/C Condenser Evaporative Cooling Assist
I am wondering if any company offers an evaporative cooler designed to reduce RV A/C condenser inlet air temp to assist in 95+ deg temps? I designed such a system (inspired by some mechanical engineers I worked with) for our residential central A/C back in the late 70's when the condensing units had coils only on one side making the design much simpler. I had the system in place during the torrid 1980 TX heat wave when peak temps reached 113 deg. The system functioned as a nearly constant condenser inlet temperature regulator. As the temperature increased during the day the relative humidity decreased and the evaporative cooling delta t increased so for outside ambient air temp of 113 deg the condenser inlet air temp was 85. This reduced compressor hgh side pressure and consequently lowered current draw. Our unit cycled nicely even in those extreme temps.
The main complication for RV A/C applications to me is the condensing air inlet being on both sides of the unit requiring some ducting of the evaporative cooler's output air or maybe an enclosure over the whole unit except for the back for the condenser's air exhaust with a single duct feeding the cooled air to the enclosure. Maybe just block off the side inlets and feed the cooled air into the units cover.
Based on Coleman's Evaluating RV A/C performance document, you would expect compressor current draw to increase 1A over LRA for every 5 deg above 95 and also decrease the same amount for every 5 deg below 95 so there would be benefits for reducing power consumption.
I would welcome any thoughts/feedback.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
