wa8yxm wrote:
Well he did say it HUMS. so I'm assuming power
If it spins easily, And it has power there are really only three suspects
1: The starting cap (you replaced it but did you get the right one and was it good)
2: The wiring (did you hook it up properly)
3: THe motor.. Start winding burned out.
In the last case spinningh it with power applied (CAUTION DANGER) will start it.. however note words CAUTION DANGER. do not turn fingers into salami and slice,.
Yep I replaced both caps and made sure they was wired back up right
I took the old ones out and took pictures just to make sure it was right
I’ve tried spinning it with the power on still no go I wonder if it’s the control box
The fan a few days before it stopped working was making a odd sound
And my wife said a few days later she went into the room and the fan was not working and the ac unit was just humming.
So I replaced the fan and both caps and still won’t go.
