tileman's avatar
tileman
Ac fan not working
I have a 2012 Fuzion 310 the back AC
Fan motor will not run
I tried replacing the two AC capacitors
With new ones fan still not starting
And then replaced the fan motor
I’ve checked all the wires no cuts and all hooked up right. The AC compressor
Will cut on but it just hums
It’s a coleman mach ac with heat strips
Even in just fan mode it won’t run.
Any other things I should look at
Thanks Ron
  • If you have setup as I do. I would swap control boards. See if problem moves with unit or board
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
