wa8yxm
Jun 18, 2016Explorer III
Icing is caused by one of two things. Reduced air flow due to use of LOW speed and clogged filters.. But from the sounds of it this is NOT your problem for you have cleaned the filters.
Low refrigerant. I have seen ONE TIME it was not low refrigerant in my life... Several where it was.. This indicates a leak in the supposed to be sealed system so you will need professional help if this is the cause.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
