Pamela1963 wrote:
I'm considering getting rid of the rooftop AC unit and installing a mini-split system in my 37 foot 5th wheel. The 5th wheel will be in a permanent/fixed location and will not be moved. It will be wired direct to an electric meter. I've seen many 'Pros', and the only 'Cons' are possible issues when traveling, which will not be an issue in my case. Any thoughts or suggestions???
It depends on what year your RV is. HOW will you route the COLD air with a split system? How will you make sure the Hot air return is getting all return air to the System? We are assuming you have 2 or 3 roof AC units and the cold air ducts run thru the roof. What is the problem with the roof air units that you want to change to another system? WHAT split air systems are you looking at? There are hundreds of thousands of RV'ers fulltiming out there that have no problem with RV roof top systems keeping their units cool. Doug
