hotpepperkid's avatar
hotpepperkid
AC not cooling
It is a Colman 15K and it is not putting out any cold air. What are things I should check before I take it somewhere to have checked out
  • Switched from FAN to FAN & COMPRESSOR you should hear and feel the compressor cut in. First step in troubleshooting.
  • clean the coils with a sprayer hose, check the filter inside the rv. Cleaning coils requires the roof a/c cover to be removed. At that time you can also check the fan on the roof to be sure there are no insect nests etc impeding the fan and/or leaves and debris on the condenser coils.
  • All they'll do when you take it somewhere is tell you that the unit is not serviceable, and it must be replaced.
    Is the compressor running when you turn it to max cool?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
