- SCVJeffExplorer
landyacht318 wrote:
Gee thanks.... There's another $10 I need to spend.. You're correct about chargers and cords. I'm finding out why some things charge, others done, and the differences in wall worts. It's amazing the charge differences in various devices
scvJeff, that one does not count mAH consumed, like this one:
http://www.amazon.com/Jelly-Comb-Universal-Multi-meter-Voltmeter/dp/B00NHHP06C/ref=sr_1_6?ie=UTF8&qid=1434248422&sr=8-6&keywords=usb+Meter
Professional Review of above USB meter:
http://lygte-info.dk/review/USBmeter%20KCX-017%20UK.html
This meter has proven helpful in my understanding of why some outlets charge various USB devices faster than others, and that the quality of the USB cord, and its length can make a huge difference.
This linked meter can test voltage at the end of a micro USB cable, and the voltage drop can be significant. - ScottGNomadA lot of those built into outlets only have a 1A charge rate so they aren't strong enough to charge many smart phones.
- landyacht318ExplorerscvJeff, that one does not count mAH consumed, like this one:
This linked meter can test voltage at the end of a micro USB cable, and the voltage drop can be significant. - landyacht318ExplorerIf you are plugged into the grid with converter going, then a 12v USB port is fine and dandy, and if you do not have grid power then a 12v USB port is more efficient.
https://www.bluesea.com/products/1016/Dual_USB_Charger_Socket
Mine holds 5.14 volts under maximum load. Can't say the same of other USB sources I have. - hersheyExplorerLowes has what your looking for. You can either replace the present AC outlet with one that has both AC and USB or buy a plug in module that has both also. I replaced one outlet with a USB only that has 4 USB outlets.
- SCVJeffExplorerYou can buy them at Home Depot, but they're not cheap, and need a box as opposed to the modular outlet in allot of RV's. You're way better off with a high current dual USB wall wort
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
