MFLNomad IIMay 23, 2015AC slightly tiltedMy FW has a rounded roof, and the draining water from the AC has always run down by the door. I had the shroud off, doing some cleaning, and could clearly see the drain spout on the driver's side of t...Show More
Old-BiscuitExplorer IIIMay 23, 2015A/C hold down bolts should be 'snug'....so snug up drivers side a little more than passenger side. Just don't crush roof gasketGasket is 1" new and gets compressed to roughly 1/2" so there is room to 'adjust'
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 30, 2026
Related Contentslightly different solar qxTruck tilting?Leaf spring shackles are tiltedTilting Solar PanelTravel Trailer Tilt
