2oldman
Jun 12, 2020Explorer II
enblethen wrote:x2 on this.
Check the neutral for melting or dark coloration on the insulation.
High amp appliances can burn up connections which present with intermittent problems. At least in my coach they do. Breakers don't always work they way they should.
My air was running poorly and I discovered the hot wire in my 30a plug was burned to a crisp, but touching just enough to run it, sort of.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
