Bredwagon's avatar
Bredwagon
Ac unit bad?
Ok here is my question. I was running my ac today in my trailer. ( plugged into shore power). I noticed that the fan would slow down and then speed back up. Also when it slows down I could here a buzzing from the breaker panel. So I shut it off right away until I could get it checked out. Does it sound like ac is bad? The trailer is a 90s model and is still the orginal ac.- it was taken very good care of. Would it better to just replace the whole unit with a newer one? Thanks.
  • Remove the breaker and look for pitting where it clamps onto the bus.
    May need a new bus & breaker. Possibly a new load center.
  • Ok I did some checking into it tonight. Good call on the breakers guys! One of the posts that holds the mounting plate for the breakers is broke. Causing the breakers to be loose and wiggle around. I wired the ac direct ( just to check!) and it is fine. So I need a new load center. I have a magnetek 6300 series model 6345. Can I get just the load center? From what I have found they don't seem to make them anymore.
  • Yeah you can buy a new panel ... suggest you give the guys at Bestconverter.com a call ... http://www.bestconverter.com/Parallax-80D-30-Amp-ACDC-Distribution-Panel_p_86.html. However. If your going to go through the trouble of switching I would probably upgrade to something that has a smart converter - if you want to camp having battery and good converter is a big plus and your old magnatek converter is pretty lousy. Bestconveter guys should be able to talk you through your alternatives. Good luck.
  • have had good luck with these, have put several in different campers, use for 30 or 50 amp and includes 12 volt panel as well, uses easy to find square d breakers!
    http://www.ebay.com/itm/WFCO-MODEL-WF-8930-50-30-50-AMP-RV-BARK-BOX-POWER-DISTRIBUTION-PANEL-BLACK-/281330275040?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item41809752e0&vxp=mtr#ht_512wt_1105
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
