mudrat025's avatar
mudrat025
a/c unit hardly working on generator power
hello,i have a 28 foot toy hauler that has an onan generator from the factory. when i bought the trailer and the salesman was showing me how everything worked he used the generator to show me that the a/c unit worked fine with generator power. however the trailer has been sitting all winter and decidied to check the ac unit before the summer heat. i did this with no shore power just the generator. the fan blows fine and after the ac unit running 15 minutes the air was barely cold. any suggestions?
  • Did you set the thermostat to the coldest setting?
    Did you hear the compressor kick on?
    How big is the generator?
    It is certainly easy to hear the compressor over just the fan. If you have access to shore-power, I would check out the air-conditioner there first to rule out problems with the unit. If the compressor does not start, check for a tripped circuit breaker.
    Now start up the generator and first check for 120v,ac, power. If the microwave will run you have 120v, ac, from the generator. No 120v,ac? check generator circuit breaker. Does your RV shore-power cord need to be plugged into generator outlet? My Fleetwood MH does. Made that mistake last spring, and took a while before I remembered that stupid mistake.
  • Does the A/C work correctly on shore power? If yes, then it is a generator or switch problem. If no, then it is an A/C problem.
    I suspect an A/C problem.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
