golf_bears's avatar
golf_bears
AC with heat pump problem????
I have a new 2017 RV with a Dometic 15,000 BTU air conditioner. The AC is equipped with a heat pump. The heat pump was working great.
Now the heat pump trips the breaker after 3-4 hours of use.
I had a 2008 RV with a 15,000 BTU AC and a heat pump that gave me the same problem. Had it checked out a number of times but no one could fix it permanently.
Anyone else out there have a similar problem? If so were you able to get it fixed? If so, what was the fix?
Thanks in advance for any suggestions on how to fix the problem permanently.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
