tenbear
Nov 01, 2015Explorer
:B
Your original post said the the voltage dropped from 11.9v at the battery to 11.35v at the inverter. That's 0.55v volts being dissipated somewhere. You said the current was over 62A.
That means over 34 watts is being dissipated somewhere. 10' of #6 wire would cause a 0.24v drop, a loss of 14.88 watts so 20 watts is being dissipated somewhere else along the battery to inverter path.
How hot would a 20watt incandescent bulb get? That could get hot enough to cause a fire under worst case conditions.
Yes, I'm an old engineer.:B
kyle86 wrote:
I figured I would test it with a small 700w kureg coffee maker and see if it could take it. The darn thing drew over 62 amps---.
On my trimetric meter at the battery, it showed voltage dropped from 12.6 to 11.9. When I measured the voltage at the inverter terminal however it was only 11.35 volts. I am using 10 ft total of 6 gauge wire---.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
