pyrosecur's avatar
pyrosecur
Activating Hydraulic jack blows fuse and stops extending
Hi All !
My Allegro 2004 gas home is equipped with HWH 325 Series Level System. One of my jacks will not extend. I have verified and found a burnt 15a fuse in the control box. I have replaced the fuse and when I activate the switch for that jack it blows again. I exchanged the solenoid location on the manifold and now it blows the fuse in the new position. I presume the problem is the wiring on the solenoid or the solenoid itself. Is there a way to verify the solenoid to be sure it is causing the fuse to blow ?
Thanks Gerry
  • It is very rare for a HWH harness to have a short. The solenoid usually is the cause of the short. What usually burns out that solenoid is you have a jack that is sticking on retraction and the red down light does not go out. That means when in STORE, the light does not go out and that leaves the power to the solenoid. Those solenoids are momentary solenoids and should not have 12 volt power to them longer than 15 minutes. If the time limit goes over 15 minutes the solenoid coil overheats and shorts out. That is the purpose of those 15 amp fuses. To protect the HWH control box from this type short. Once the last Red jack down light goes out the power to the solenoids is turned OFF. Doug
  • You can also ohm out the coil in the solenoid and compare it to a good solenoid. I can help you over the phone or maybe you can find electrical person to help you. There should be a specific ohmic value when you measure between the two leads that go into the solenoid. I have been a professional electrical electronic troubleshooter all my Life and I also suspect it’s the solenoid as well.
  • Hi Bud, thanks for the manual links.... I found mine and it sounds like the solenoid is the problem.
    When you say "Test solenoid conductors for any continuity to ground." Should there be continuity or not ? (I'm not very electrical :) )
    Gerry
  • Disconnect wiring from the solenoid. Test solenoid conductors for any continuity to ground.
    Check wiring to the jack down conductors for broken or pinch.
    I will go to my rig and pull troubleshooting manual.
