JaxDad
Jul 12, 2021Explorer III
pianotuna wrote:
JaxDad,
Thanks--rv is 28 feet 5 inches and a class c. It has a rubber roof of some kind.
I won't need to angle--but a quick release might be worth while.
What is a 4t deg (I don't understand the t)?
4t is what you get when try to type 45 on an iPad without enough caffeine… LOL
I would use 2 sets of quick release latches to both allow angling (maximum sun on winter days when it’s low in the sky) and easy removal.
It will be easier to match body width and mount the legs atop the walls, that way any weight (and or snow load) would be carried by the wall not the roof. Then adjust fore / aft length to match square footage required.
There is aluminum extrusions available that you could buy cut to length and bolt together Mechano set-like.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 01, 2026
