- RbertalottoExplorerUPDATE!
Hardened the propane feed area...
There is a flat steel metal support between the tire and my propane plumbing. This is where I attached an aluminum box I fabricated to protect the propane pipe in the event of a catastrophic tire failure.
Also keeps the quick connect hose and the QC nice and clean
- So, the set up you did here is 11" water column right? I need to run a high pressure line from the tanks to my gas grill. My trailer came with the high pressure tap already installed before the regulator and a quick connect with hose. I am thinking of leaving that in place running 3/8" stainless with stainless compression fittings (2000psig rating)to the grill and having a quick connect at each end. When I want to use the grill, I can "hot up" the line at the tank quick connect and hook up a quick connect hose at the grill. The only drag would be having to purge the line prior to lighting up.
Thoughts? - RbertalottoExplorerI might "harden" this area with a metal box of some sort. To protect it from a blow out or road debris.
- Dutch_12078Explorer IIINice work, but that ball valve hanging down next to the tire concerns me. If road debris or a blow out damaged the valve, you could have a serious problem.
- RbertalottoExplorerAll four " feeds" are not isolated in any way. What is a propane isolation valve?
- SaltiDawgExplorerIs there an isolation valve upstream of where the new line ties in? Should there be one?
- CalicajunExplorerNice write up, I was wondering how hard it would be to install an extra propane line.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
