enblethen
Oct 06, 2015Nomad
Locate your battery control center. You may need to operate the battery disconnects and listen for it's location. That is if rig has battery disconnects.
If you have battery disconnects, look to see if there is another large relay in the same area. It would have two large posts and one or two small posts. One side of it would go to chassis battery and one side would go to the coach battery. Trace out the wire that is on the small post(s) One should get power when the rig is running the other should connect to ground.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
