I have an older Springdale (1999)...I want to add a receptacle so I can plug in my laptop, charge the cell phone etc. I have a spot that I can access in a storage compartment into the wall of the livi...
You might be better to tap into an existing plug, run the wire on the inside of the wall through a conduit, through a hole in the floor, under the camper, up another hole to your desired location, through another conduit and attach a plug on the inside of your desired location. Attempting to feed a line in the walls of an RV is impossible without removing the outer skin or inside paneling.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
