hammick
Apr 10, 2015Explorer
Adding a portable panel to roof mounted panel
I have a 160w Go Power panel (specs below) on the roof of my toyhauler fed to a Blue Sky Sun Charger 30 PWM CC. 208ah battery bank (two Interstate GC2 in series). Built in Onan 4000W generator. No large inverter and no plans to add one (just a small 750w for running TV).
Looking for good advice on adding a panel on the ground that I can point East in the morning and West in the afternoon. I don't want to spend the fortune Go Power wants for their portable kits.
Most of our camping is boondocking. I would describe us as light energy users. All lights are led. The portable unit would be nice so we could boondock at campfire rings under the trees.
Assuming we would wire Parallel. Not sure about diodes.
Thanks for any advice!
Solar cell type Monocrystalline
Output power
160 W
Rated current
9.14 A
Rated DC voltage
17.5 V
Open-circuit voltage 21.0
Module efficiency 17.8%
Connectivity MC4 connectors
Frame type Silver anodized aluminum frame
Certifications CE
Dimensions 58.3 x 26.5 x 1.38 in / 1482 x 674 x 35 mm
Weight
24.5 lbs / 11 kg
Warranty
25 years (module) / 5 years (controller)
Output power
160 W
Rated current
9.14 A
Rated DC voltage
17.5 V
Certifications CE
Weight
24.5 lbs / 11 kg
Warranty
