rk911
Oct 02, 2019Explorer II
mitchmitchell1616 wrote:rk911 wrote:
yes. we did that a year or so ago. the only downside is that if we check the tanks on the inside panel we have to wait until that panel resets before we can check levels on the exterior panel. otherwise the exterior panel simply duplicates what is showing on the interior panel.
Awesome! Did you simply splice into the existing tank wiring? Also, how did you protect the exterior panel from weather (rain etc.).
Thanks!
i didn't do the work...my shop did. the panel is flush mounted (no punntended) in the wet bay. i may be seeing the tech this weekend. if so i'll see about getting some answers for you.
i had the remote panel installed not so much as to help with dumping....i use a clear elbow section during the dump and flush to monitor when the flow changes to clear. the panel is there to enable me to monitor the fresh tank level while filling it.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
